15 years agoError while downloading linux image - NIOS 2 with MMU
Hello, I'm getting the below error while downloading the linux image onto NIOS-2 with MMU. I'm getting this error after updating quartus and nios2eds to version 11.0. The same image worke...
15 years agoDid you update the uClinux? The sopc-create-header-files is replaced with devicetree method in the updated version. If you have updated the uClinux, perhaps that's why you are having problems.
I would suggest you to use a design with MMU, together with the devicetree method. For that you will need to follow the guide in (http://www.alterawiki.com/wiki/linux_for_the_nios_ii_processor) and the following thread: (http://alterauserforums.org/forum/showthread.php?t=29720) I hope these suggestions will help. If you want to continue with the older method, I don't know what is really going wrong. Cheers, Turhan
