15 years agoError while downloading linux image - NIOS 2 with MMU
Hello, I'm getting the below error while downloading the linux image onto NIOS-2 with MMU. I'm getting this error after updating quartus and nios2eds to version 11.0. The same image worke...
15 years agoHello Chetan.
Please make sure you are following (http://www.altera.com/support/kdb/solutions/rd07292010_420.html) correctly. Is your DDR2 s1 address range 0x10000000 to 0x1fffffff and all the other components in between 0-0x0fffffff? Also did you change /linux2.6/arch/nios2/include/asm/nios.h? (DDR2_TOP_BASE to 0x10000000, and DDR2_TOP_SPAN to 268435456 (256Mb)) Give them a try... All the best, Turhan
