Error to add HEX file in Convert Program File tool - 2
I have a question very similar to the one discussed in the following thread:
The problem is that there no is no such option as: options ->memory editor ->read or write hexadecimal files (.hex) using byte addressing (intel format).
I am using Quartus 16.1. I am attaching the screen shot of my Quartus 16.1. It may be seen clearly that there is no such option available. Is there any alternative to that?
- Ftiglius
HI, Anand! Thanks! I confirm you that I have EPCQ_CONTROLLER_xxxx.hex file
After JIC file configuraion , FPGA starts correctly but Nios fails booting. Attached there is map file. To create Hex, I used Boot in Place istructions from edh_ed_handook, section 5.2.3.3.
I use external SDRAM, when I develop my app it runs all on SDRAM and from JTAG all its ok.....
