TRoa
7 years agoError to add HEX file in Convert Program File tool - 2
I have a question very similar to the one discussed in the following thread: https://forums.intel.com/s/question/0D50P00003yyTIESA2/error-to-add-hex-file-in-convert-program-file-tool?language=en_US ...
TRoa
7 years agoThank you sir. Again I followed the procedure in the above post. Everything went fine, except the last created jic file, upon downloading, the circuit was not working.
Btw, the addresses in hex file are starting at zero. Please correct me I am wrong. i also adopted the procedure to generate (through save as method in memory editor), any hex file, but that generated file is also starting at address number 0(zero).
I generated files (hex) with specific names through command line. I am sure that I am picking the right files
When I am trying to attach files here, "answer" button gets deactivated.
Is there any way I can share files with you?
Best and deep regards
TRoa
