TRoa
7 years agoError to add HEX file in Convert Program File tool - 2
I have a question very similar to the one discussed in the following thread: https://forums.intel.com/s/question/0D50P00003yyTIESA2/error-to-add-hex-file-in-convert-program-file-tool?language=en_US ...
AnandRaj_S_Intel
7 years agoHi,
I can you attach hex file in directory and conversion image and .map file?
Their may be two or more hex file we need to select appropriate one with name something like PERIPHERALS or EPCQ.
Create .jic file and check.
You should verify that the generated .map file has Page_0 at a start address of 0x0, and the hex file at a start address 1 after the end address of Page_0.
Anand Raj Shankar
