15 years agoError probability UART RS232
Hello everyone, Is there any way to reduce the error probability in a serial transmission using the UART provided by Altera? For a baudrate of 115200 bps there is a Pe = 0.001 (1 erronous byte ...
15 years agoI am using the uart corresponding http://www.alterawiki.com/wiki/fifoed_avalon_uart
My system clock has a frequency of 144 MHz, enough for sampling the serial line. Also, in my tests, it is achieved the maximum baud: In the FPGA the elapsed time between receiving the first character until the last is 1250 ms, when I transmit 14400 characters in the computer. (14400 characters * 10 bits/character) /115200 (bits/sec) = 1250 ms The error in the status register comes when: assign rxd_shift_reg = unxshiftxrxd_shift_regxshift_reg_start_bit_nxx6_out; assign {stop_bit,raw_data_in,unused_start_bit} = rxd_shift_reg; assign is_break = ~(|rxd_shift_reg); assign is_framing_error = ~stop_bit && ~is_break; always @(posedge clk or negedge reset_n) begin if (reset_n == 0) unxshiftxrxd_shift_regxshift_reg_start_bit_nxx6_out <= 0; else if (clk_en) unxshiftxrxd_shift_regxshift_reg_start_bit_nxx6_out <= unxshiftxrxd_shift_regxshift_reg_start_bit_nxx6_in; end assign unxshiftxrxd_shift_regxshift_reg_start_bit_nxx6_in = (do_start_rx)? {10{1'b1}} : (sample_enable)? {sync_rxd, unxshiftxrxd_shift_regxshift_reg_start_bit_nxx6_out[9 : 1]} : unxshiftxrxd_shift_regxshift_reg_start_bit_nxx6_out; assign rx_in_process = shift_reg_start_bit_n; assign sample_enable = baud_clk_en && rx_in_process; ... I suppose the error comes when a bit is out of sync, probably one of the last bit of the 10 sampled bits.
