15 years agoError probability UART RS232
Hello everyone, Is there any way to reduce the error probability in a serial transmission using the UART provided by Altera? For a baudrate of 115200 bps there is a Pe = 0.001 (1 erronous byte ...
15 years agoIs that meant to be the probability that a valid async character will treated as an error, or that random noise will be treated as a valid character?
A UART clock is likely to be 4 times the baud, and the middle 2 clocks of each bit time can be compared for equality - giving 10 bit pairs that must match per character. Except that the both samples of the stop bit must be zero, and the start bit (probably) has to last 3 samples. OTOH if your clock is slow you may not want to wait for all the stop bit (to avoid missing the next start bit). Or, a different sum. At 115k, a 4x clock is 460k, to guarantee a 1% (or better) clock you'll need to divide down from 50x460k or 23MHz. You need a 2.5% error on a 4x clock to get one clock out before the end of an async char - so 1% should be plenty! I suspect some standard will quote a closes tolerance though - it all depends on the way the UART logic is defined.
