NanjundaM
8 years agoError flashing the QSPI NOR Flash connected to HPS with Command shell
Hi, We are seeing few errors flashing the QSPI NOR Flash connected to HPS with Command shell as per the link: https://rocketboards.org/foswiki/Documentation/A10Gsrd161QspiBoot#Programming_QSPI Bel...
Daixiwen
8 years agoIs it on a development kit or a custom PCB? If custom, which flash are you using?
On our custom PCB we have the same problem when using a Micron MT25QL512ABB8E12-0SIT but it works fine with a Cypress S25FL512SAGBHIC1.
I didn't investigate that much because both the flash are working with our own software, that uses a lower frequency than the quartus_hps command line tool. It could be signal integrity problems but we were careful when routing the board, and adding 33 ohm resistors on the lines didn't change anything.
I haven't found a way to reduce the clock frequency quartus_hps uses either, and if anyone knows I'd be interested.
