8 years agoError (204012): Can't generate netlist output files because the file ..
hello.. i am new in altera. recently i start to develop project with qsys nios ii/s using altera web version. but when i am starting compilation of code it shows error like... Error (20401...
8 years ago --- Quote Start --- Hi, 1.Which type of NIOS II are you using? use Nios II economy and check. Yes, you can program FPGA with web edition. Regarding Lincence refer below links https://www.altera.com/support/support-resources/support-centers/licensing.html https://www.altera.com/support/support-resources/download/licensing/lic-q2se_licenses.html https://www.altera.com/support/training/demonstrations/online/licensing/onl-licensing.htm.html https://www.altera.com/support/support-resources/download/licensing/overview.html Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- thank you sir...
