8 years agoError (204012): Can't generate netlist output files because the file ..
hello.. i am new in altera. recently i start to develop project with qsys nios ii/s using altera web version. but when i am starting compilation of code it shows error like... Error (20401...
8 years ago
1.which type of nios ii are you using? use nios ii economy and check. sir i am using nios ii/s. if this nios_cpu.v is not generating.then how dump this file on FPGA i am not understanding. will you plz,elaborate the same further.
