8 years agoError (204012): Can't generate netlist output files because the file ..
hello.. i am new in altera. recently i start to develop project with qsys nios ii/s using altera web version. but when i am starting compilation of code it shows error like... Error (20401...
8 years agoHi,
1.Which type of NIOS II are you using? use Nios II economy and check. --- Quote Start --- but my actual question is, it is possible to dump my project file on FPGA with out only this file. --- Quote End --- Yes, you can program FPGA with web edition. --- Quote Start --- if it is not possible then how get this ip licence.or i need to buy only ip licence or required altera pro version tool. --- Quote End --- Regarding Lincence refer below links https://www.altera.com/support/support-resources/support-centers/licensing.html https://www.altera.com/support/support-resources/download/licensing/lic-q2se_licenses.html https://www.altera.com/support/training/demonstrations/online/licensing/onl-licensing.htm.html https://www.altera.com/support/support-resources/download/licensing/overview.html Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
