15 years agoEPCS16 and problems
Hi guys. I met a problem.As i understand, I am not first person,which has same problems. Lets go. When i try to program flash memory(Altera EPSC16N) by HW and for this purpose i have .jic file...
14 years agoI am having the same issue with an EPCS64N. I have two boards running identical .sof loads - one works and returns this from nios2-flash-programmer:
Looking for EPCS registers at address 0x30000400 (with 32bit alignment) Initial values: 00000000 00000000 00000260 00000000 00000000 00000001 Valid registers found epcs signature is 0x16 EPCS identifier is 0x202017 Using EPCS size information from section [EPCS-202017] Device size is 8MByte (64Mbit) Erase regions are: offset 0: 128 x 64K EPCS status is 0x00 The other fails and returns this: Looking for EPCS registers at address 0x30000400 (with 32bit alignment) Initial values: 00000000 00000000 00000260 00000000 00000000 00000001 Valid registers found epcs signature is 0xff EPCS device doesn't support RDID command No EPCS layout data - looking for section [EPCS-FF] Unable to use EPCS device Leaving target processor paused Does anybody know why an identical (in theory) circuit and device would return a signature of 0xFF? I have replaced the EPCS64N - same result. I checked the DCLK, DATA, nCS, and ASDI signals with a scope and all look good and similar between boards. Are there bad devices floating around? (These were purchased from DigiKey - an authorized Altera distributor.)
