11 years agoELF File Error in Eclipse Build Tools for Nios II for Qsys System
I have a Qsys system with a Nios II processor which aims to detect an sd card and turn on LED 0 if one is detected (via code from the Nios II Software Biold Tools for Eclipse). When I try to run my Eclipse code on my DE0-Nano board (SD card is soldered to a header which is on some GPIO pins), I get a couple errors:
In the Console: C:\altera\14.1\Programs\sdtesing\sd_interface\software\sd_lib_bs[/HAL/src/alt_main.c:154: undefined reference to `main' make : *** [sd_connect.elf] Error 1 and in a popup: Project does not have an ELF file. Please make sure project has been built successfully. The program compiles and loads to the board successfully in Quartus. The BSP and Application created without any errors. A tutorial program which loads a program with Eclipse runs fine. My code and Qsys program are below. If you have any suggestions for either, they would be much appreciated. I'm fairly new to Quartus and very new to Qsys systems, so I'm grateful for any help. Devices: DE0-Nano Kingston 4GB SD Card Windows 7 Quartus 14.1 Code: # include <io.h># include <system.h># include <altera_up_sd_card_avalon_interface.h> void led_on(){ //turns on LED_0 while(1){ IOWR(LED_BASE, 0, 1); } } int main(){ alt_up_sd_card_dev *device_reference = NULL; device_reference = alt_up_sd_card_open_dev("/dev/Interface"); if((device_reference != NULL) && (alt_up_sd_card_is_Present())){ //if there is an SD Card detected... led_on(); //do the thing that turns an LED on } return 0; } Qsys system: (See attachment)1 Reply
I am sorry to say that the file you have attached is hardly visible. on the nios console are you getting an error like: " find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer." please let us know.
