14 years agoEclipse doesn't recognize the hardware
hello, I am new to the Nios 2. I own a DE1 board and can't seem to get the "Nios 2 hardware development tutorial" to function. Here is the problem: when I run the Nios II 11.1 Software Build...
14 years agoTry to install it and use it as administrator.
Also you can do it by command line. Compile your project then change the directory to the .elf folder. type nios2-download -g FILE.elf; nios2-terminal and there it is
