14 years agoDownloading ELF Process Failed
Hello There, I am trying to Download my simple "Hello World " Code on nios-ii but each time it says "Downloading ELF Process failed", i have port the nios-ii processor on board, i am using A...
14 years agoYou should try to make the smallest system possible that still has the problem, by disabling as much component as possible, and then compare it with a system that works. Hopefully it will give you an indication of where the problem comes from, as I don't have any other idea to give you right now...
