16 years agoDowloading elf process failed
I have a simple Nios 2 program with a nios 2 cpu and off chip SRAM. I use the University program IP core SRAM controller with a de2 board. I can generate the system successfully but I get several ins...
15 years agoHi,
Some info that may help: for the issue discussed above please note the document : "Nios II Embedded Design Suite Release Notes and Errata", errata on page 55, " issue : Error Running Nios II Project: ‘Downloading ELF Process failed’ ". It solved the same problem described above in my case. Dani
