16 years agoDowloading elf process failed
I have a simple Nios 2 program with a nios 2 cpu and off chip SRAM. I use the University program IP core SRAM controller with a de2 board. I can generate the system successfully but I get several ins...
16 years agoPhil -
I have the same issue as you. I have a prototype pcb I am in debug with and there are a myriad of issues. The design has a 3c120 ethernet, 2 sdram banks and a cfi flash interface. All of the interfaces seem to have issues so I made a stripped down version of the embedded system and compiled "hello world niosii" targeting a 32Kx32 internal block memory (defined as a rom) theres also 32kx32 data ram. Idea here is to get something to load and run code, then write diags to debug the rest. I added a timer based task that flashes a led on via a pio every 3 seconds I incorporate the .hex file into the build and assume it's picking it up and building it into the .sof The system does not boot - when I try to just send the elf code I get Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x18004D40: verified Initializing CPU cache (if present) OK Downloading 030C0000 ( 0%) Downloading 030C0120 ( 0%) Downloading 030D0000 (70%) Downloaded 91KB in 1.6s (56.8KB/s) Verifying 030C0000 ( 0%) Verify failed between address 0x30C0000 and 0x30C001F Leaving target processor paused look similar?
