17 years agodouble write pulse using only one single IOWR_16DIRECT
Hi, I've hooked up a CFI flash (8MB) to the Tristate bus. I've managed to get the CFI query working, however, I can't write to the flash at all. Observing the bus, I've found out that every IOW...
14 years agoThe nios cpu always does 32bit master accesses, so if your slave is narrower than 32bits a 'bus width adapter' is added - that converts the single 32bit cycle into 2 or 4 cycles with the approprate byte enables asserted.
Moreover the nios always asserts all 4 byte enables on reads. You really are better off writing a 32bit wide slave.
