17 years agodouble write pulse using only one single IOWR_16DIRECT
Hi, I've hooked up a CFI flash (8MB) to the Tristate bus. I've managed to get the CFI query working, however, I can't write to the flash at all. Observing the bus, I've found out that every IOW...
16 years agoHi Jeff,
I got my system to work by turning off the data cache 'enable bursts'. I have been using 9.1 for my compiles. When you started from scratch, does your system have the 'enable bursts' turned off? Anyway, having the data cache write back bursts turned off is o.k. in my system. Thanks for the help, Steve
