17 years agodouble write pulse using only one single IOWR_16DIRECT
Hi, I've hooked up a CFI flash (8MB) to the Tristate bus. I've managed to get the CFI query working, however, I can't write to the flash at all. Observing the bus, I've found out that every IOW...
16 years agoNo one complained about this. I believe that this occurs uniquely to my SPOC system which was created since version 7.2, then migrated to 8.0. Some setting causes the thing to happen. I had to work around by having some and/or logic together with the write enable/byte enable to suppress the second pulse.
It's quite wierd. Thanks :) If i start every thing from scratch in version 8.0, it works perfectly.
