17 years agodouble write pulse using only one single IOWR_16DIRECT
Hi, I've hooked up a CFI flash (8MB) to the Tristate bus. I've managed to get the CFI query working, however, I can't write to the flash at all. Observing the bus, I've found out that every IOW...
16 years agoHi Jeff,
When the software team wrote the nios2-flash-programmer utility, how did they get past the problem? Did it not come up internally? Also, is there a possibility of getting the source code for flash programmer? Thanks, Steve
