17 years agodouble write pulse using only one single IOWR_16DIRECT
Hi, I've hooked up a CFI flash (8MB) to the Tristate bus. I've managed to get the CFI query working, however, I can't write to the flash at all. Observing the bus, I've found out that every IOW...
17 years ago@dim: attached image for your reference: up_a[1] ==> connected to LSB of your Flash depending on the mode of operation.
Jeff contact me at [email protected] if you need me to give you the reference codes.
