17 years agodouble write pulse using only one single IOWR_16DIRECT
Hi, I've hooked up a CFI flash (8MB) to the Tristate bus. I've managed to get the CFI query working, however, I can't write to the flash at all. Observing the bus, I've found out that every IOW...
17 years agoBingo,
Problem solved ... Here's what I did: Delete the NIOS processor and instantiate it again ... working fine ... I've been using the NIOS created by my colleague using SOPC 7.2 --> the CFI Flash doesn't work ... because of the double write access ... Now, I just deleted the NIOS and instantiate a new one --> working fine ... In both cases, I always use SOPC v8 sp1. ... Can any expert tell me what is going on underneath? .... This thing was really tiring!!! Regards, Jeff
