17 years agodouble write pulse using only one single IOWR_16DIRECT
Hi, I've hooked up a CFI flash (8MB) to the Tristate bus. I've managed to get the CFI query working, however, I can't write to the flash at all. Observing the bus, I've found out that every IOW...
17 years agoCan you describe how did you connect your Flash?
i have a problem: i can't even read from Flash. so would be so kind to explane: your pins of Flash are they input or output? can you make a screenshot of pins in top-level og quartus?
