15 years agoDoes anyone try the "Board Test System" on the Cyclone III dev kit?
Hi, All I want to try the "Board Test System" fucntion on the Cyclone III dev kit (Cyclone3c120_dev_kit). When I followed the steps on the "Cyclone III FPGA Development Kit User Guide" chape...
15 years agoThanks for your reply. :oops:
I know I do not give much more information. But it is not easy to description the problem which I met. If I fix this problem, I will try to give the problem and method togather. Anyway, thanks again for you. --- Quote Start --- You did not write how it did not work. Without those info, hard to help you out. I assume the most of people has issue with either multiple blaster connection (I assume this BTS only can detect 1 balster at a time) different Quartus version is activated (BTS has version dependency) board itself has sometihng issue you have different version of JRE(Java Runtime Environment) you are running it on win7 or Vista. I think this BTS only support XP32bit officially. --- Quote End ---
