10 years agoDMA vs MSGDMA
What is the difference betwen DMA and MSGDMA? Which is better to use?
10 years agoCan your hardware handle the data come in as a stream? If so you might not need to temporarily copy it to SDRAM and just have the DMA pull it out and stream it to your hardware using Avalon-ST. Then you can have another DMA pull the data using Avalon-ST and write it back to memory.
