14 years agodma questions
Hey! I'm runing some test using the DMA controller. I started with the simplest one, trying to copy some datas from an onchip memory to another. I'm using this code.
static volatile int rx_don...
14 years agoYou also need to ensure that the cpu doesn't access parts of the same cachelines while the dma is in progress,
