14 years agodma questions
Hey! I'm runing some test using the DMA controller. I started with the simplest one, trying to copy some datas from an onchip memory to another. I'm using this code.
static volatile int rx_don...
14 years agoI've tried with a data cache of 4,8,16 Kb...for 8 and 16 the transfer did't work at all, an for 4 it has the same problems as before.
I also added the alt_dcache_flush_all(); instruction at the beginning of the main function.
