14 years agodma questions
Hey! I'm runing some test using the DMA controller. I started with the simplest one, trying to copy some datas from an onchip memory to another. I'm using this code.
static volatile int rx_don...
14 years agohello again!
Today i made some modifications to the SOPC project ( i added an external RAM) so i can run some more tests( ram-> onchip memory and onchip->onchip). Now the code and all the software components are on the ram. The results are strange..to say the least. i observed the following situations: onchip->onchip: works almost perfectly, but with a delay of one program run, for both chars and ints.(for ints works from the first run after i change the transfer type from onchip->onchip,and then gets this delay)length=10
Transfer TX successful!
Transfer RX successful!
send
5 6 7 8 9 10 11 12 13 14
received
1 2 3 4 5 6 7 8 9 10
int NOT OK
length=10
send
received
int OK
length=10
send
10 11 12 13 14 15 16 17 18 19
received
int NOT OK
length=10
send
received
int OK ram->onchip : works perfectly for chars, but for ints is working only at the first run after i change the transfer type. the thing is that earlyer this morning, the ram->onchip worked perfectly( for 12 ints) after i made this change in the code: if ((rc = alt_dma_txchan_send (txchan,send,length*sizeof(int)*2,done_tx ,NULL)) < 0), after that it didn't work anymore whith that *2. :confused: Have a nice day! alex
