15 years agoDMA problem on alt_dma_txchan_send
Hi every body.
I have a problem with the NIOS DMA setting. In my system, I need to read data from a device by a MM-Avalon interface, and write the data in a other device with the MM-Avalon interface. The memoryes in the devices are FIFO. The part of my code about DMA is: # include "system.h" # include <io.h> # include <stdio.h> # include <sys/alt_irq.h> .... int rc; alt_dma_txchan txchan; alt_dma_rxchan rxchan; void* tx_data = (void*) (MC_BASE+MC_READ); void* rx_buffer = (void*) (GIGAINT_BASE); if ((txchan = alt_dma_txchan_open(DMA_0_NAME)) == null) ret++; alt_dma_txchan_reg (*pTxchan); if(alt_dma_txchan_ioctl(txchan,ALT_DMA_SET_MODE_32,null)<0) printf ("Failed to set ALT_DMA_SET_MODE_32 in TX\r\n"); if(alt_dma_txchan_ioctl(txchan,ALT_DMA_RX_ONLY_OFF,tx_data)<0) printf ("Failed to set ALT_DMA_RX_ONLY_OFF in TX \r\n"); if(alt_dma_txchan_ioctl(txchan,ALT_DMA_TX_ONLY_ON,tx_data)<0) printf ("Failed to set ALT_DMA_TX_ONLY_ON in TX \r\n"); if ((rxchan = alt_dma_rxchan_open(DMA_0_NAME)) == null) ret++; if(alt_dma_rxchan_ioctl(rxchan,ALT_DMA_SET_MODE_32,null)) printf ("Failed to set ALT_DMA_SET_MODE_32 in RX\r\n"); if(alt_dma_rxchan_ioctl(rxchan,ALT_DMA_TX_ONLY_OFF,rx_buffer)) printf ("Failed to set ALT_DMA_TX_ONLY_OFF in RX \r\n"); if(alt_dma_rxchan_ioctl(rxchan,ALT_DMA_RX_ONLY_ON,rx_buffer)) printf ("Failed to set ALT_DMA_RX_ONLY_ON in RX \r\n"); rc = alt_dma_txchan_send ( txchan,tx_data,length,null,null); if (rc < 0) printf ("Failed to post transmit request, reason = %i\r\n", rc); rc = alt_dma_rxchan_prepare (rxchan,rx_buffer,length,done,null); if (rc < 0) printf ("Failed to post read request, reason = %i\r\n", rc); while (!rx_done); .... "done" is the function to call when the DMA end. "length" is 256, and teh DMA dimension is 1024 The problem is the function < alt_dma_txchan_send > return -22, but i don't understand where is the bug. Help me!!! Thank you1 Reply
I had the same issue.
In my case I had accidentally kept the width of DMA length register as 4 bits, resulting in the -22 error you described. To solve this, I adjusted the width of the DMA length register to 13 bits (default setting). This is good enough for most transfers.
