14 years agoDifficulty Encounted for Implementing A Simple FPGA Design
We have DE0 (Developement and Education) board and we have a supporting software along with the Board. While we are implementing the its my first FPGA Project as per the guide lines given in ...
14 years agoYou can't select the pins of another dev kit to use in your design. You need to select the pins according to your DE0 since the pins would be connected differently.
Your DE0 datasheet should give you a list of all the pins. Change the pins according to the datasheet and don't follow the other pdf.
