14 years agoDHCP Timed Out problem in simple socket server
Hi, I am running simple socket server for rgmii from Nios2 Eclipse template. I could get the Auto negotiation passed and Link established successfully. However the DHCP server fails to acquir...
14 years ago --- Quote Start --- what did you mean by flaws in my application? --- Quote End --- I meant the Nios application, not your telnet client. I suggested you use ping instead of telnet, because ping use only a minimal part of the network stack, so it's less prone to any software/driver problem. In other words, ping always works when telnet (or generic tcp connection) does; the reverse is not true. --- Quote Start --- By the way, other than defining the IP address in the simple socket server.h file and disabling the DHCP Server through BPS Editor, what se should I do to configure the system to be using Static IP address? --- Quote End --- Ok. This is enough. --- Quote Start --- Do you think that unconstraint design will cause DHCP Server fails to acquire an IP address? --- Quote End --- Timing problems can lead to very subtle defects, not easy to identify and reproduce. From your description the problem seems to be located at the mac/phy level, but I can't say if due to timing or any logic error. I'd exclude any error on Nios sw/driver side, since you said you are using the sss template with nearly no changes. Timing: make sure you have at least the minimal (core) constraints; you should have time quest analysis enabled, timing driven synthesis option checked and your project must include the .sdc file generated by sopc builder / Qsys Logic: check if the RGMII signals are correctly routed to the proper fpga pins connected to ethernet phy. Also check in the Nios terminal log: it should report the ethernet phy has been identified, initialized and ethernet link established.
