14 years agoDHCP Timed Out problem in simple socket server
Hi, I am running simple socket server for rgmii from Nios2 Eclipse template. I could get the Auto negotiation passed and Link established successfully. However the DHCP server fails to acquir...
14 years agoHi Cris, what did you mean by flaws in my application? I got this unique static IP address my IT departmentand I assume it should be able to "telnet" if my design is working. By the way, other than defining the IP address in the simple socket server.h file and disabling the DHCP Server through BPS Editor, what se should I do to configure the system to be using Static IP address?
As I am using the simple socket server from template in Nios2 SBT Eclipse, it is using Nichestack TCP/IP Stack and MicroCOS II software packages. Do you think that unconstraint design will cause DHCP Server fails to acquire an IP address?
