14 years agoDHCP Timed Out problem in simple socket server
Hi, I am running simple socket server for rgmii from Nios2 Eclipse template. I could get the Auto negotiation passed and Link established successfully. However the DHCP server fails to acquir...
14 years agotelnet involves a tcp connection and may be affected by flaws in your application.
You'd better start with a simple: ping <IP_address> Anyway if you have concerns on ethernet interface and fpga configuration and timing, you need more specific tests. What are you using, Nichestack? uC/OS2 or superloop?
