14 years agoDHCP Timed Out problem in simple socket server
Hi, I am running simple socket server for rgmii from Nios2 Eclipse template. I could get the Auto negotiation passed and Link established successfully. However the DHCP server fails to acquir...
14 years agoWhen DHCP server fails to acquire an IP address, could it be something wrong with the flash? In fact, i am a lil confused on how the SSS program actually generate the M number if AC and IP addresses based on the board serial number if the flash is absolutely empty.
One more culprit is that I am using 125MHz on board clock and scale it down to 50MHz using PLL in my Qsys system. Timing constraint has been done, yet there are still some violations. Thanks.
