8 years ago
Device Tree - Registering IRQ in Linux GIC
Hello everyone.
I've done some design using Qsys and I'm trying to get my Device Tree to work. I took the *.dtb from GHRD and changed to a *.dts (so I would be able to modify it as I wish).
Also, I generated the device tree through sopc2dts (I guess this is the command) and the *.dtb file it generates doesn't boot my board, so something is getting messed up. What I did in order to solve the problem is the following: I took the IPs that are are inside the
hps_0_bridges: bridge@c0000000
and I put the IPs that I use in my qsys design.
         msgdma@0x100000000 {
               compatible = "altr,msgdma-15.0", "altr,msgdma-1.0";
                reg = <0x00000001 0x00000000 0x00000020>,
                         <0x00000001 0x00000020 0x00000010>;
                reg-names = "CSR", "Descriptor_Slave";
                interrupt-parent = <&hps_0_arm_gic_0>;
                interrupts = <0 43 4>;
                clocks = <&clk_0>;
	hps_0_arm_gic_0: intc@fffed000 {
		compatible = "arm,cortex-a9-gic-15.0", "arm,cortex-a9-gic";
	# interrupt-cells = <3>;
		interrupt-controller;
		reg = <0xfffed000 0x1000 0xfffec100 0x100>;
		reg-names = "axi_slave0", "axi_slave1";
		linux,phandle = <0x2>;
		phandle = <0x2>;
The thing is I can't register the interrupt 43 onto GIC... (I only checked the proc/interrupts file)
https://alteraforum.com/forum/attachment.php?attachmentid=13492&stc=1
Anyone knows what might be causing the problem? Currently I can use all my peripherals from lw and my fpga2sdram bus. This mSGDMA writes to the ARM SDRAM, and the design works well, but I can't get this IRQ thing to work.
Thanks in advance!
1 Reply
    --- Quote Start ---
    Hello everyone.
                    clocks = <&clk_0>;
            phandle = <0x2>;
    Thanks in advance!
    --- Quote End ---
    For those who might be struggling with the same stuff... I have developed a device driver which runs some come in the kernel that deals with the hardware from FPGA.
