14 years agoDevice ID
I know you can set your own custom SystemID, but can the Nios processor get the *device* id, so it can work out what actual chip the core is running on ? I have a design that is used on both EP...
14 years agoSorry. I misunderstood your question yesterday.
I try now to give you the correct answer. Some time ago I had found this information in another thread. It's a bit tricky but it works. The (hardware) device id is stored in the epcs configuration data. You can retrieve it with the following procedure: - read the config data in EPCS memory a byte at a time, starting at offset zero - discard 0xFF for an arbitrarily long time - if you find anything other than 0x56, this is not config data - extracting bit 4 (mask 0x10) from EPCS bytes 52 to 59 and packing them (LSB first) will give the device ID (e.g. 0xF1 to 0xF6 for Cyclone III) - like searching for the Software-Device ID code, the configuration bitstream length is encoded in a particular bit of a run of bytes: Total length field is 32 bits; the 7 most significant bits are encoded in bit 4 (mask 0x10) of EPCS bytes 33 to 39; the remaining 25 bits are encoded in bit 5 (mask 0x20) of EPCS bytes 48 to 72 (LSB first in each run). The length is expressed in bits, so we must discard the last 3 bits to get the byte length This algorithm is implemented in Nios bootloader in order to find out the firmware location in epcs.
