14 years agoDevice ID
I know you can set your own custom SystemID, but can the Nios processor get the *device* id, so it can work out what actual chip the core is running on ? I have a design that is used on both EP...
14 years agoSystemID is like a normal MM slave.
You can simply read the 32bit device id with IORD(SYSID_BASE, 0) At offset 1 (IORD(SYSID_BASE, 1) you also find a timestamp of the core generation date and time.
