8 years agoDevice change in * .pof file
Using Quartus and Atera USB programmer we have to load component PM7128AETI100 on pc with Win7 64 bit. We have to load *.pof file created for device EPM7128AT100. EPM7128AT100 is not supported in Quartus. Can we change *.pof file device to device PM7128AET100 supported in Quartus? Thanks,5 Replies
--- Quote Start --- we have to load component PM7128AETI100 Thanks, --- Quote End --- Do you mean EPM7128AETI100 1.Which version of quartus tool you are using? Max7000 device is supported from quartus version 10 till quartus version 13. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
We use version 14.0.0. Yes, EPM7128AETI100. I will try to download version 13 and give a try. Thank you, - Altera_Forum
I tried in version 13.0. After opening of *.pof file there is error "Error (210009): Device EPM7128AT100 is not supported". Is there a way, how to adapt *.pof file to compatible and supported device? Best regards, Pavel - Altera_Forum
EPM7128AT100 is supported quartus 13 in check the image 1.For which device .pof file is generated? 2.which device you are trying to program? Can you attach the pof file. https://www.alteraforum.com/forum/attachment.php?attachmentid=14652 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
I tried version in Quartus version 13 32 bit and version 14 64 bit. I uploaded also pof file. Pof is generated for device EPM7128ATI100-10. Best regards, Pavel
