9 years agoDesign works with NIOS II/e, not II/f
I have a design in whch I read ADC samples from PIO with a dual clock FIFO input and transport the output data with SGDMA to on-chip memory. It took me a few days of experimenting to discover ...
9 years agoWhat do you mean with 'not working' ?
Your design runs but you don't get the expected results or do you mean you can not run the code at all? In the second case, please note that while Nios II/e is offered free of charge, Nios II/f requires a license. If you don't have one, you must run the design with the USBblaster connected, otherwise the Nios II/f would stop working.
