14 years agoDelay in receiving a byte in SPI slave rxbuffer
Hi, I am currently working on a project in which I am interfacing the ANT transceiver (AP2) to the Altera DE2 board through SPI.The ANT transceiver is the master SPI and altera FPGA is the slave S...
14 years agoHello,
Thanks for the reply! Actually I solved the issue. I figured out that in the slave SPI of NiosII, the slave select line always has to go high in order to store a byte in the rxbuffer. Initially I had grounded it so that the slave SPI is always selected . But in that configuration the slave SPI didn't reset itself and ignored the MOSI byte. So now after I pull the slave select line low, I pull it high after a delay in order to receive the byte on MOSI line.
