8 years agoDefining a code section besides ".text" section
I am working with a design that includes: - Nios II processor version "e" - On chip memory dedicated for data and instructions I used the SBT to write a function in assembly langage. This function is called in main: void function() __attribute__((section(".function"))); int main() { alt_printf("Hello function\n\r"); function(); return 0; } Actually, I added to the linker file a section ".function" that will contain the code of the function. I have defined it after the ".text" section. .text : { . . . } > memory = 0x3a880100 /* NOP instruction (always in big-endian byte ordering) */ .function : AT ( LOADADDR (.text) + SIZEOF (.text) ) { PROVIDE (function_mem_start = ABSOLUTE(.)); *(.function) . = ALIGN(4); PROVIDE (function_mem_end = ABSOLUTE(.)); } > memory The problem is that when I execute my code, it never runs the "function()" code. Each time the nios reaches "function", it restarts the execution of the program from the beginning. Hence, I get an infinite "Hello function" printed in the console. However when I delete "__attribute__((section(".function")))" from the main program, the program is executed correctly and my function code is saved in the ".text" section. My question is, why I can't execute a program from a section other than ".text" and what should I do to make it possible? Thank you,No RepliesBe the first to reply
