14 years agodebug loses calling function
hi there,
i already have a new problem that seam a little mystery, at least to me. when I'm debugging my design i can follow the called functions in the debug window (see below). 5 process_action() receiving_msg.c:145 0x040032584 recv_msg() receiving_msg.c:60 0x04002ec0
3 comtask() http.c:161 0x04001a08
2 wstask() http.c:485 0x04002394
1 osstarttsk() os_cpu_a.s:268 0x0404090c c but at some point the three functions I would return to last disappear. 2 process_action() receiving_msg.c:147 0x04003268
1 recv_msg() receiving_msg.c:60 0x04002ec0 the function "recv_msg()" will disappear sometime in the process as well. when i return through the other functions I'm getting as new last function <symbol is not available>. 2 process_action() receiving_msg.c:190 0x04003458
1 <symbol is not available> 0x00000000 at that point the program freezes. the first disappearing happens at a strcpy(local char[], global struct.char[]) command. but if i use this command in the function called before "process_action()" it has no effect. any ideas how i can prevent losing my calling history? Thanks in advance. rico
1 Reply
You might be overwriting the stack.
