15 years agoDE2-70 board Nios II USB problem
I got the error when i tried to run my C code in Nios IDE environment with Altera DE2-70 board. My project is very simple (control the LEDs by the switches), everything seems fine, until I tried ...
15 years agoBecause the tutorial with incorrect the pin name variable, so we have to change it to correct one. For example, CLOCK_50 signal in tutorial should be iCLK_50, and so one. You could look at the DE2_70_pin assignment file, and you will find the correct pin name. FYI the user manual also wrong with the pin name
