14 years agoDE2-115: Problem - ISP1362 Does Not Work
Hi guys, I am using DE2-115 board configured with SOPC file from included DE2-115 CD (DE2_115_NIOS_DEVICE_LED). I removed all components except the following: - pll - jtag_uart - cpu...
14 years ago --- Quote Start --- ykozlov: Yup, I did. Isn't it has to be enabled if hardware divide option is enabled in Nios II processor? Thanks and regards, Gladion --- Quote End --- MULX is 64-bit Multiply and is different from MUL. I don't think it's related to DIV. If you have an instruction enabled in your build that the processor doesn't have, you're going to run into problems.
