14 years agoDE2-115: Problem - ISP1362 Does Not Work
Hi guys, I am using DE2-115 board configured with SOPC file from included DE2-115 CD (DE2_115_NIOS_DEVICE_LED). I removed all components except the following: - pll - jtag_uart - cpu...
14 years agoHi,
--- Quote Start --- Well, I leave it to that one to default setting, since it usually works in this way. Hmm, will try on this and tell you guys about the results. ^^ --- Quote End --- I'm using the old '20080619' version sources which Wind River guys threw to Nios Wiki community.This version has many problems around mmu's macros and we can't select the main memory base address freely except 0xc0000000. Of cource, I don't know that the latest version improves these or not, but I recommend you to delete the residual offset. Kazu
