8 years agode10 nano ethernet phy clock loanio
Hi everybody, I'm working on an implementation of openpowerlink (http://openpowerlink.sourceforge.net/web/openpowerlink/documentation.html) for the de10-nano platform. The powerlink fpga code ne...
8 years agoI remember seeing some sort of similar issues if I implement SignalTap inside the design. If you have SignalTap, try removing that and see if that helps. If not, try using one of the clocks that are generated from the HPS itself (User Clock 0 or 1)
