8 years agoDE1 AUDIO CODEC help needed
I am using DE1-SOC audio codec. I have sound by linking ADCDAT to DACDAT. I do this with a switch. So I can disable sound or listen to it by using this switch. The next step is to make a 24 bits left and right data from ADCDAT and then manipulate it and get it back to DACDAT. So I made 2 processes: The following converting ADCDAT to 24 bits data left and right PROCESS(BCLK,NRST) BEGIN if NRST = '0' then AUD_DACLRCK_OLD <= '1'; GO <= '0' ; index <= 0 ; ch <= 0; temp <= conv_std_logic_vector(0, 24) ; elsif rising_edge(BCLK) then if AUD_DACLRCK_OLD = '1' AND AUD_DACLRCK = '0' then ch <= 1; AUD_DACLRCK_OLD <= '0' ; index <= 24; end if; if AUD_DACLRCK_OLD = '0' AND AUD_DACLRCK = '1' then AUD_DACLRCK_OLD <= '1' ; ch <= 2; index <= 24 ; end if; if ch = 1 then if index >= 0 then temp(index) <= AUD_ADCDAT ; end if; index <= index - 1 ; if index = -1 then RES_LEFT <= temp(23 downto 0) ; ch <= 0;end if; end if; if ch = 2 then if index >= 0 then temp(index) <= AUD_ADCDAT ; end if; index <= index - 1 ; if index = -1 then RES_RIGHT <= temp(23 downto 0) ; ch <= 0; end if; end if; end if; --rising_edge END PROCESS; For getting it back to 1 bit: PROCESS(BCLK,NRST) variable i,j : integer; BEGIN if NRST = '0' then i := 0; j := 0; LR <= '0'; GO <= '0'; elsif rising_edge(BCLK) then --if rising_edge(START) and GO = '0' then AUD_DACLRCK_OLD <= AUD_DACLRCK; if AUD_DACLRCK_OLD = '0' AND AUD_DACLRCK = '1' then ch <= 0;ch2 <= 1; data_left <= datain_left; data_right <= datain_right; j := 24 ; end if; if AUD_DACLRCK_OLD = '1' AND AUD_DACLRCK = '0' then ch <= 1; ch2 <= 0; i := 24; end if; if (ch = 1) then if i >=0 and i <= 23 then AUD_DACDAT <= data_left(i) ;end if; i:= i-1; elsif (ch2 = 1) then if j >=0 and j <= 23 then AUD_DACDAT <= data_right(j) ;end if; j:= j-1; end if; --GO if i <0 then ch <= 0; end if; if j <0 then ch2 <= 0; end if; end if; END PROCESS; So if I connect ADCDAT to DACDAT I get perfect sound. But if I do it as above I get too much noise. Any idea? I appriciate your help...No RepliesBe the first to reply
