14 years agoDDR2 and Ethernet
Hi friends, I want to control DDR2 and Ethernet with NIOS II on my board. ADC results are read from LVDS_rx module and store on DDR2 and then stream out via Ethernet. On my board, there is no...
14 years ago --- Quote Start --- It's done by DDR2 controller in SOPC. I've already mentioned that You need either DMA or own memory master core. --- Quote End --- oh, i see... Can I use the DDR2 memory as two separate blocks ,one for nios ii cpu and the other fo adc result ?
