21 years agoCYGNUM_HAL_RTC_CONSTANTS
Hi! I am trying to use the RTC constants (in order to calculate time from ticks), and I've seen something strange with them. In the file altera\kits\nios2\components\ecos\ecos...
21 years agoI think you're right. It looks like these constants are back to front. I believe that what's given below is more correct (although I'll need to do some further testing to be sure):
* Construct some intermediate defines that are used to extract the timer
* configuration from the auto-generated system.h header file.
# define ALT_AVALON_TIMER_PERIOD_UNITS_S 0# define ALT_AVALON_TIMER_PERIOD_UNITS_MS 1# define ALT_AVALON_TIMER_PERIOD_UNITS_US 2# define ALT_AVALON_TIMER_PERIOD_UNITS_CLOCKS 3
# define __ALT_CLK_BASE(name) name##_BASE# define _ALT_CLK_BASE(name) __ALT_CLK_BASE(name)# define ALT_SYS_CLK_BASE _ALT_CLK_BASE(CYGHWR_HAL_SYSCLK_DEV)
# define __ALT_CLK_IRQ(name) name##_IRQ# define _ALT_CLK_IRQ(name) __ALT_CLK_IRQ(name)# define ALT_SYS_CLK_IRQ _ALT_CLK_IRQ(CYGHWR_HAL_SYSCLK_DEV)
# define __ALT_CLK_PERIOD(name) name##_PERIOD# define _ALT_CLK_PERIOD(name) __ALT_CLK_PERIOD(name)# define ALT_SYS_CLK_PERIOD _ALT_CLK_PERIOD(CYGHWR_HAL_SYSCLK_DEV)
# define __ALT_CLK_PERIOD_UNITS(name) name##_ALT_AVALON_TIMER_PERIOD_UNITS# define _ALT_CLK_PERIOD_UNITS(name) __ALT_CLK_PERIOD_UNITS(name)# define ALT_SYS_CLK_PERIOD_UNITS _ALT_CLK_PERIOD_UNITS(CYGHWR_HAL_SYSCLK_DEV)
# define __ALT_CLK_FREQ(name) name##_FREQ# define _ALT_CLK_FREQ(name) __ALT_CLK_FREQ(name)# define ALT_SYS_CLK_FREQ _ALT_CLK_FREQ(CYGHWR_HAL_SYSCLK_DEV)
* Having extracted the timer constants, use these to contruct the real time clock constants
* required for eCos.
# define CYGNUM_HAL_RTC_CONSTANTS (1)
# define CYGNUM_HAL_RTC_NUMERATOR (1000000 * ALT_SYS_CLK_PERIOD *
((ALT_SYS_CLK_PERIOD_UNITS == ALT_AVALON_TIMER_PERIOD_UNITS_S ) ? 1000 : 1))# define CYGNUM_HAL_RTC_DENOMINATOR ((ALT_SYS_CLK_PERIOD_UNITS == ALT_AVALON_TIMER_PERIOD_UNITS_US ) ? 1000 :
(ALT_SYS_CLK_PERIOD_UNITS == ALT_AVALON_TIMER_PERIOD_UNITS_CLOCKS ) ?
(ALT_SYS_CLK_FREQ/1000) : 1)# define CYGNUM_HAL_RTC_PERIOD (ALT_SYS_CLK_FREQ / CYGNUM_HAL_RTC_DENOMINATOR /
((ALT_SYS_CLK_PERIOD_UNITS != ALT_AVALON_TIMER_PERIOD_UNITS_S ) ? 1000 : 1))
# define CYGNUM_HAL_INTERRUPT_RTC ALT_SYS_CLK_IRQ Thanks for pointing this out!
